Cyberdevs Posted August 3, 2023 Share Posted August 3, 2023 Hi guys, To respect the wishes of the OpenCore Legacy Patcher developers in order to minimize the risk of making more issues I've decided to remove the nightly builds from the download section. "Do not distribute direct links to the nightly builds, instead please link back to this pull request. As stated on SOURCE.md, these builds should be used very carefully: Warning: Nightly builds (untagged builds built from the latest commit) are actively developed OpenCore Legacy Patcher builds. These builds have not been tested, are not guaranteed to work, and are not guaranteed to be safe. Do not use nightlies without a good reason to do so, and do not use them on your main machine. Additionally, these binaries should not be used without first consulting the CHANGELOG. Do not share any links to these binaries in forums; please link to this document only. Additionally, do not reupload these binaries or download binaries from other sites. Using binaries from untrusted sources is a security issue, as they may have been tampered with. Users running new builds of the project without understanding what has changed and the implications of installing software under active development are at a higher risk of bricking their installation as they do not read any warnings provided in the CHANGELOG. We wish to minimize these situations as much as possible." You can read all about it here and here If you want to build them yourself you can also see this topic: https://community.macmeup.com/index.php?/topic/79-opencore-legacy-patcher/#comment-81 But if anyone needs help on making them from the source you can post your questions here. Sorry for the inconvenience. Link to comment Share on other sites More sharing options...
Recommended Posts
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new accountSign in
Already have an account? Sign in here.
Sign In Now
