Cyberdevs Posted July 27, 2023 Share Posted July 27, 2023 OpenCore Legacy Patcher is now available for macOS Sonoma, It’s an early preview so please read this before using it: https://github.com/dortania/OpenCore-Legacy-Patcher/pull/1077#issuecomment-1646934494 The procedure to build OCLP for macOS Sonoma is the same as macOS Ventura but you need to download it for macOS Sonoma at: https://github.com/dortania/OpenCore-Legacy-Patcher/tree/sonoma-development You need to have these installed before being able to build the OCLP: Xcode or Xcode Command Line Tools on your host OS Python 3.6 or newer if you've got any installation errors use python 3.10 for generating the binaries Download the OCLP 0.6.9 from the link above Open terminal and type cd then drag the OpenCore-Legacy-Patcher-sonoma-development folder to the terminal then press enter. Your prompt should look something like this: user@users-Mac-Pro OpenCore-Legacy-Patcher-sonoma-development % Type pip3 install -r requirements.txt and once the installation is done you can run the Build-Binary.command inside the OpenCore-Legacy-Patcher-sonoma-development folder to build the latest version of the OCLP Once it’s done open: OpenCore-Patcher-GUI.command or you just can find the GUI application inside the "dist" folder which you can use on any system running macOS Sonoma. If you don’t want to compile OCLP from repo you can just download and use the prebuilt version of it: Nightly Link: OpenCore-Patcher.app (Sonoma Development) Remember OCLP for macOS Sonoma is beta stage and it’s also in constant development so you need to update it frequently. If you need to know how to use OpenCore Legacy Patcher see these guides: https://macmeup.com/building-oclp-alpha/ or https://macmeup.com/easily-use-oclp-to-install-macos-on-your-mac/ 2 Link to comment Share on other sites More sharing options...
Recommended Posts
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new accountSign in
Already have an account? Sign in here.
Sign In Now
